MOD Arduino Shield
Revision as of 21:57, 23 September 2018 by Leogermani (talk | contribs) (adjusting content in wrong section)
We introduce the MOD Arduino Shield. A shield that enables the Arduino to interface with MOD through our Control Chain.
The MOD Arduino Shield was designed to help developers and hackers who wants to create their own effects controllers for MOD.
The main idea is that, with little effort, anyone can design and assemble the electronics of any sensor, integrate with Arduino and then with MOD.
The MOD Arduino Shield is compatible with Arduino UNO, Arduino MEGA and Arduino DUE.
This project is open hardware! All the project files, not only the schematics and gerber, are open and available in our Github. We are using KiCad, also an open source software, for developing our boards and cases schematics. All the components are listed in the bill of materials with links for the general suppliers.
And it is also open software. We developed an Arduino Control Chain library that will do all the hard work so developers can easily implement their own cases.
We will present here some successful cases and help you with your development. The cases will come with electronic schematics, tested code examples, bill of materials, images and manuals.
But the MOD Arduino Shield is not restricted by these cases.
We have ideas of hacking a scale and use the weight sensor to control the distortion, a heart beat monitor that controls the delay of the sound, and even brain waves monitor for controlling the MOD. It goes way further.
The cases here are supposed to be cheap and easy, so if it gets difficult, let us know! (subscribe on developers list)
Infographic of MOD Arduino Shield possibilities
Hardware Project Files
Images
Components for the MOD Arduino Shield Assembly
MOD Arduino Shield Prototype 1 PCB
MOD Arduino Shield Prototype 1 Assembled
MOD Arduino Cases
  • Accelerometer
Control any effect parameter using an accelerometer. Control up to six parameters using the six degrees of freedom, three axis acceleration and three axis rotation.
Main article: Arduino Case: Accelerometer
  • Distance
Control any effect parameter using an ultrasound distance sensor.
Main article: Arduino Case: Distance Sensor
  • Expression Pedal
Control any effect parameter using an expression pedal. Not only the usual wah-wah pedal - you can control tune, frequency, gain just like if you were changing a potentiometer value. Cames with an extra button for bypass, trigger or toggle effects/parameters.
Main article: Arduino Case: Expression Pedal
  • Footswitch
Control and switch parameters using a footswitch. Expand your MOD by adding four extra footswitches.
Main article: Arduino Case: Footswitch
  • Light Sensor
Control any effect parameter using a light sensor. The change of light will change the sound.
Main article: Arduino Case: Light Sensor
Tutorial
TODO
External references
https://maker.pro/ - an active, open source platform for maker projects much like Hack A Day. These projects are centered around Arduino, Raspberry Pi, Intel Edison, home automation and more. And better yet, the content is completely user generated.
https://www.allaboutcircuits.com/ - extremely active electrical engineering online community that provides both interesting content and useful resources for Electrical Engineers.
