Testing Plugins
WARNING: This page is currently being written, please check in later!
Error checking
Using SDK, needs py3lilv out of scope of this, see lilvlib for debian and osx
Plugin Data Validation
With RDF data it is possible to check the syntax and semantics. Syntax means, for example, you have not written a comma where ought to be a semicolon.
Valid semantic means, for example, there is no AudioPort
which is InputPort
and OutputPort
at the same time.
Preparation
Assuming you have installed sord_validate
with your system package manager.
We clone the upstream LV2 repository:
$ cd ~/Downloads
$ git clone http://lv2plug.in/git/cgit.cgi/lv2.git/
$ cd lv2
These files might be also distributed in a package of your system package manager, e.g. package lv2
on Arch Linux.
The reason to clone the upstream source is your package data might be stale and we don't want to waste time
with errors that are already fixed!
First let's check the release itself is not broken. The following should give no errors:
$ sord_validate $(find . -name '*.ttl')
Found 0 errors among 88 files (checked 1834 restrictions)
Second we need to have the definitions of the MOD extentions (which are documented at [1] and [2]).
$ cd ~/Downloads
$ mkdir ns-mod-ttl
$ cd ns-mod-ttl
$ wget http://moddevices.com/ns/mod/mod.doap.ttl
$ wget http://moddevices.com/ns/mod/mod.ttl
$ wget http://moddevices.com/ns/modgui/modgui.ttl
$ wget http://moddevices.com/ns/modgui/modgui.doap.ttl
Let's also check if the set union of the two is still valid:
$ sord_validate $(find ~/Downloads/lv2/ -name '*.ttl') $(find ~/Downloads/ns-mod-ttl/ -name '*.ttl')
Found 0 errors among 92 files (checked 1889 restrictions)
Now we are prepared.
Validate Your Plugin
What sord_validate
does is, reading in the whole world of triples and proving that there are no conflicts with the rules. The rules are stated in the definitions you downloaded above.
If you can list your created Turtle files like this
$ find ~/.lv2/mybundle.lv2 -name '*.ttl'
/home/username/.lv2/mybundle.lv2/manifest.ttl
/home/username/.lv2/mybundle.lv2/seealso.ttl
then you can validate them by adding this command in the back:
$ sord_validate $(find ~/Downloads/lv2/ -name '*.ttl') $(find ~/Downloads/ns-mod-ttl/ -name '*.ttl') $(find ~/.lv2/mybundle.lv2 -name '*.ttl')
The result should be 0 errors. That's it.
Stress tests
Your plugin builds, runs and can be found on the LV2PATH. Let's test the code.
Testing with lv2bm
Download and compile the tool with
$ cd $MY_GITHUB_DIR
$ git clone git@github.com:moddevices/lv2bm.git
$ cd lv2bm
$ make DEBUG=1
Optionally you can install it on your system path. Make sure, you also built your plugin with debug symbols.
If your plugin has the URI http://example.org/mybundle
then you run the tool with:
$ ./lv2bm --full-test http://example.org/mybundle
[Inferior 1 (process 5735) exited normally]
If your plugin crashes you can investigate it with
$ gdb --args ./lv2bm --full-test http://example.org/mybundle
(gdb) run
for example.
Torture tester
There is another tool to test LV2 plug-ins called Torture tester. Install and build it:
$ cd $MY_GITHUB_DIR
$ git clone git@github.com:cth103/plugin-torture.git
$ cd plugin-torture
$ make
Again we don't install it on the system path.
Run it with
$ ./plugin-torture -d -a -e --lv2 -p ~/.lv2/alo.lv2/manifest.ttl
Of course, you can wrap this with GDB as well. See ./plugin-torture -h
for the arguments explained.
Does it load on MOD?
mod-host trick
