Stable Releases
1.6 2018/5/10 Commercial Plugin Store; New Pedalboard screenshot process; Stable -> Beta; Display brightness control menu option modduo-v1.6.0.591.tar
  1. Turn on your MOD
  • NEW: Global Tempo
  • NEW: Settings Panel
  • Add zita-njbridge package
  • fix audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
