Publishing Plugins
Revision as of 02:57, 16 December 2017 by Lazzarello (talk | contribs) (local build documentation)
Local Deploy
Plugins are stored in
/root/.lv2/
. Typically, directories end up here through the UI installation system, which downloads the bundle from a URL. It is also possible to build a plugin locally and manually copy the archive to this directory. The following process works as of firmware 1.5. The root password is "mod".
Install new plugin
scp -r myplugin.lv2 root@modduo.local:~/.lv2/
Upgrade plugin
ssh root@modduo.local
# enter password
cd .lv2/
mv myplugin.lv2 ../myplugin.lv2.bak
mv ../myplugin.lv2 .
Each option must be followed by a hard power off.
Unstable Plugins
To enable the Mod hosted unstable plugin repository, go to the URL with the mod attached via USB http://modduo.local/settings Click the Advanced tab. Check the box to enable unstable plugins.
