Control Chain
About
Comparing to MIDI, Control Chain is way more powerful. For example, instead of using hard-coded values as MIDI does, Control Chain has what is called device descriptor and its assignment (or mapping) message contains the full information about the parameter being assigned, such as parameter name, absolute value, range and any other data. Having all that information on the device's side allows developers to create powerful peripherals that can, for example, show the absolute parameter value on a display, use different LED colors to indicate a specific state, etc.
The Control Chain devices are connected to the MOD using a regular Ethernet patch cable and they have two connectors, what allows a next external controller to be connected, creating then a chain. The MOD will provide power supply to the controller via the patch cable.
How to use Control Chain devices
Once a new firmware of a Control Chain device be available the Web interface will warn you. To proceed with the upgrading click on Download button to download the latest firmware and then follow the instructions on the screen that is also replicated here.
Upgrading the Footswitch Extension (XF4)
- Disconnect the XF4 device from the Control Chain port
- Hold down the footswitch #1 on the XF4 device
- While the footswitch is pressed, connect the XF4 to the MOD via USB cable
- Disconnect the XF4 from the USB port
Upgrading Arduino based devices
Troubleshooting
If you are having problems trying to upgrade the device via Web GUI, for example the GUI doesn't recognize the device connection, please follow the below instructions in order to manually upgrade the firmware of your device.
XF4
- Open a terminal and execute the command bellow
curl http://download.moddevices.com/releases/cc-firmware/v1/file/XF4-latest.bin | ssh root@192.168.51.1 "cat > /tmp/xf4-latest.bin && nxp-usb-isp /tmp/xf4-latest.bin"
