Revision as of 14:26, 29 June 2017 by FalkTX (talk | contribs)
Stable Releases
1.4 2017/06/29 Control Chain modduo-v1.4.0.448.tar
  1. Turn on your MOD
  • quick fix for audio inputs DC offset
  • Control Chain support
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
