| Date | Main features | Download link | |||||
| 1.4 | 2017/06/29 | Control Chain | modduo-v1.4.0.443.tar | 1.3 | 2017/03/28 | Pedalboard presets; Click-less bypass; 'MIDI Utility' category | modduo-v1.3.2.357.tar |
| 1.2 | 2017/01/23 | Favorites; Tap-Tempo; Zeroconf; DNS fix; Minor interface changes | modduo-v1.2.1.275.tar | ||||
| 1.1 | 2016/10/31 | Bluetooth Network; Control Outputs; Remember MIDI devices and connections; Tuner | modduo-v1.1.3.tar | ||||
| 1.0 | 2016/08/24 | Auto-update; Load pedalboards with MIDI programs; Load remote pedalboards; UTF-8 fixes | modduo-v1.0.6.tar | ||||
| 0.15.0 | 2016/06/21 | Preset support; Fixed xruns | |||||
| 0.14.0 | 2016/05/23 | Bugfixes only | |||||
| 0.13.0 | 2016/05/09 | Allow javascript in modguis; Optimizations to plugin store | |||||
| 0.12.2 | 2016/04/19 | Add "default" pedalboard | |||||
| 0.11.3 | 2016/03/22 | Implemented leds peak-meter | |||||
| 0.10.4 | 2016/03/08 | Volume/gain via controller; Access banks after disconnecting USB cable; Firefox compatible | |||||
