Developers
The MOD Duo runs a highly-optimized Linux embed system, using JACK as audio server and loading plugins in LV2 format.
Plugin parameters can be controlled via the Duo's built-in knobs and footswitches, via MIDI CC and Pitchbend or via Control Chain devices.
Technical information
As of release 1.1 the MOD Duo runs the Linux kernel version 3.4, with real time patch.
ALSA is used for the audio driver. JACK runs inside as audio server backend, with mod-host loading each LV2 plugin as a new (internal) JACK client as mod-ui as the web server.
mod-plugin-builder
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.shThis process should take at least 1 hour, probably more depending on your CPU.
$ . ~/mod-plugin-builder/local.env
Quick example plugin
A quick example plugin is available inside mod-plugin-builder in make -C plugins/package/eg-amp-lv2/source/, which works with this cross-compilation setup.
Deploying plugins
$ cd ~/mod-plugin-builder/plugins/package/eg-amp-lv2/
APIs and Documentation
For more information see:
JACK
LV2
- http://web1.moddevices.com/shared/ns/mod/
- http://web1.moddevices.com/shared/ns/modgui/
Toolchain
- GCC 4.9
- glibc 2.21
- binutils 2.25
This means support for C99 and C++11.
Libraries
- acl
- alsa
- armadillo
- audiofile
- boost
- cairo
- dbus
- expat
- fftw/fftwf
- ffmpeg
- flac
- fluidsynth
- fontconfig
- freetype
- gio/giomm
- glib/glibmm
- glibc (v2.21)
- icu
- jack
- libffi
- libgig
- libjpeg/libturbojpeg
- liblo
- libogg
- libpng
- libsamplerate
- libsigc
- libsndfile
- libvorbis
- libxml2
- lilv
- lvtk
- mxml
- ncurses
- ne10
- pcre
- pixman
- python (v3.4)
- readline
- serd
- sord
- sratom
- systemd (v219)
- zita-convolver
- zita-resampler
Developer mode
This includes:
- Network statistics
- Xrun counter
enable_dev_mode()
disable_dev_mode()
Unstable plugins
Use with caution.
USB Device Support
- Several USB-MIDI devices
Hardware Specification
CPU:
- Dual Core ARM A7 1.0GHz
- 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
- 2 knobs with LCD screen
I/O CONNECTIONS:
