Developers
The MOD Duo (as of release 1.1) runs Linux, version 3.4, with real time patch.
ALSA is used for the audio driver. JACK runs inside as audio server backend, with mod-host loading each LV2 plugin as a new JACK client as mod-ui as the web server.
mod-plugin-builder
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.sh
$ . ~/mod-plugin-builder/local.env
$ make
Quick example plugin
A quick example plugin is available inside mod-plugin-builder in make -C plugins/package/eg-amp-lv2/source/, which works with this cross-compilation setup.
Deploying plugins
You can push a bundle to the MOD Duo via command-line, using curl, by running this: (adjust as needed)
$ cd ~/mod-plugin-builder/plugins/package/eg-amp-lv2/
That's it! Your plugin is now inside the MOD!
APIs and Documentation
For more information see:
Toolchain
  • GCC 4.9
  • glibc 2.21
  • binutils 2.25
This means support for C99 and C++11.
JACK
LV2
Developer mode
This includes:
  • Buffer size change (128 or 256 frames)
  • Network statistics
  • Xrun counter
   enable_dev_mode()
   disable_dev_mode()
Unstable plugins
Use with caution.
Libraries
  • acl
  • alsa
  • armadillo
  • audiofile
  • boost
  • cairo
  • dbus
  • expat
  • fftw/fftwf
  • ffmpeg
  • flac
  • fluidsynth
  • fontconfig
  • freetype
  • gio/giomm
  • glib/glibmm
  • glibc (v2.21)
  • icu
  • jack
  • libffi
  • libgig
  • libjpeg/libturbojpeg
  • liblo
  • libogg
  • libpng
  • libsamplerate
  • libsigc
  • libsndfile
  • libvorbis
  • libxml2
  • lilv
  • lvtk
  • mxml
  • ncurses
  • ne10
  • pcre
  • pixman
  • python (v3.4)
  • readline
  • serd
  • sord
  • sratom
  • systemd (v219)
  • zita-convolver
  • zita-resampler
USB Device Support
  • Several USB-MIDI devices
Hardware Specification
CPU:
  • Dual Core ARM A7 1.0GHz
  • 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
  • 2 knobs with LCD screen
I/O CONNECTIONS:
  • USB HOST – USB 2.0 Standard-A type, supporting: USB Bluetooth, USB Wifi, USB MIDI
