Developers
The MOD Duo (as of release 1.1) runs Linux, version 3.4, with real time patch.
ALSA is used for the audio driver. JACK runs inside as audio server backend, with mod-host loading each LV2 plugin as a new JACK client as mod-ui as the web server.
mod-plugin-builder
In summary:
$ cd mod-plugin-builder
$ ./bootstrap.sh
$ . ~/mod-plugin-builder/local.env
$ make
Quick example plugin
A quick example plugin is available inside mod-plugin-builder in make -C plugins/package/eg-amp-lv2/source/, which works with this cross-compilation setup.
Deploying plugins
We can deploy compiled LV2 plugins to the MOD using MOD-SDK or via command-line using curl.
$ export LV2_PATH=~/mod-plugin-builder/plugins/package/eg-amp-lv2/
$ modsdk
Then open a browser at localhost:9000, select a plugin from the list and use the "deploy" tab to push the selected plugin's bundle to the Duo.
$ cd ~/mod-plugin-builder/plugins/package/eg-amp-lv2/
That's it! Your plugin is now inside the MOD!
APIs and Documentation
For more information see:
Toolchain
- GCC 4.9
- glibc 2.21
- binutils 2.25
This means support for C99 and C++11.
JACK
LV2
- http://web1.moddevices.com/shared/ns/mod/
- http://web1.moddevices.com/shared/ns/modgui/
Developer mode
This includes:
- Network statistics
- Xrun counter
enable_dev_mode()
disable_dev_mode()
Unstable plugins
Use with caution.
Libraries
- acl
- alsa
- armadillo
- audiofile
- boost
- cairo
- dbus
- expat
- fftw/fftwf
- ffmpeg
- flac
- fluidsynth
- fontconfig
- freetype
- gio/giomm
- glib/glibmm
- glibc (v2.21)
- icu
- jack
- libffi
- libgig
- libjpeg/libturbojpeg
- liblo
- libogg
- libpng
- libsamplerate
- libsigc
- libsndfile
- libvorbis
- libxml2
- lilv
- lvtk
- mxml
- ncurses
- ne10
- pcre
- pixman
- python (v3.4)
- readline
- serd
- sord
- sratom
- systemd (v219)
- zita-convolver
- zita-resampler
USB Device Support
- Several USB-MIDI devices
Hardware Specification
CPU:
- Dual Core ARM A7 1.0GHz
- 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
- 2 knobs with LCD screen
I/O CONNECTIONS:
