MOD Duo
Development
We launched a crowd funding kickstarter campaign to raise funds to produce the MOD Duo.
Read more in our website.
Technical specs
- width: 180 mm
- length: 160 mm
- height: 74.7 mm
Audio
- 2 independent inputs:
- TS connectors
- Digital input impedance selector
- line 1 MΩ
- microphone 3 kΩ
- instrument 75 kΩ
- Programmable Gain Amplifier: ± 12 dB Gain, 0.5 dB step plus a 32 dB gain stage for microphone
- 2 independent outputs:
- TRS connectors (balanced)
- Volume Control: 0 to -127 dB, 0.5dB step
- Headphone output:
- TRS connector
Each input/output uses a Neutrik® connector, a True Bypass circuit and has a LED whose color depends on the audio signal amplitude.
- signal < -30dB : off
- -30dB < signal < -12dB : green
- -12dB < signal < -3dB : yellow
- signal > -3dB : red
- MIDI IN connector - DIN 5 pins - for musical instruments and controllers
USB
- USB Bluetooth
- USB Wifi
- USB MIDI
- USB Ethernet Adaptor
- USB Mass Storage (used for updates)
Controllers
- 2 knobs with LCD screen
Processors
- A20 CPU:
- Dual Core ARM A7 1.0GHz
- 1 GB RAM
- 4 GB Flash Storage
- Audio CODEC:
- Manufacturer: Cirrus Logic
- DAC: 104dB dynamic range, -90dB THD+N
- ADC: 104dB dynamic range, -95dB THD+N
- 24 bit / 48 kHz AD/DA
Peripherals
Software
