Audio Through USB
Jump to navigation
Jump to search
Using netJACK2
sudo ufw allow 19000Then, ssh into the Duo, and run:
touch /data/enable-netmanager
systemctl start jack-netmanagerNOTE: You only need to run this command once. The next the Duo boots, jack-netmanager will be loaded by default. Delete the /data/enable-netmanager file inside the Duo to remove this auto-start feature.
jackd -R -P 80 -d net -a 192.168.51.1 --opus -C 2 -P 2 -i 1 -o 1 -l 4 -n mod-slave -sor if you prefer to use jackdbus:
jack_control eps realtime true eps realtime-priority 80 ds net dps multicast-ip 192.168.51.1
jack_control dps opus 0
jack_control dps input-ports 2 dps ouput-ports 2 dps midi-in-ports 1 dps midi-out-ports 1
jack_control dps latency 4 dps client-name mod-slave dps auto-save true
jack_control startAdjust the parameters as needed, but keep mod-slave as the client name.
Parameters explained
| -a | Multicast address, in this case the IP address of the MOD Duo. |
| --opus | Use Opus compression, optional as it is not needed, the USB connection should be able to handle raw data. It is recommended to use compression though to decrease the risks of getting x-runs as much as possible. |
| -C | Number of audio input ports on the slave. This determines the number of audio output ports on the MOD Duo, marked as "Hardware Audio To Slave" ports in the web interface. |
| -P | Number of audio output ports on the slave. This determines the number of audio input ports on the MOD Duo, marked as "Hardware Audio From Slave" ports in the web interface. |
| -i | Number of MIDI input ports on the slave. This determines the number of MIDI output ports on the MOD Duo, marked as "Hardware Midi To Slave" ports in the web interface. |
| -o | Number of MIDI output ports on the slave. This determines the number of MIDI input ports on the MOD Duo, marked as "Hardware Midi From Slave" ports in the web interface. |
