Troubleshooting Reinstall
Revision as of 13:49, 13 June 2017 by FalkTX (talk | contribs)
If the main MOD OS becomes unbootable for some reason, the MOD will try to automatically boot into restore mode (used for performing OS updates).
  1. Turn off your MOD
  2. Hold the left knob and footswitch down
  4. Wait 5 seconds and let go of the knob and footswitch
  7. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive
  8. Disconnect the USB cable
Factory Reset
  4. Download this file: http://download.moddevices.com/releases/modduo/reset/modduo-v1.3.2.394-reset-image.raw
If you're running macOS, run:
./bootfix.osx -w ~/Downloads/modduo-v1.3.2.394-reset-image.raw
./bootfix -w ~/Downloads/modduo-v1.3.2.394-reset-image.raw
Continuing:
Reinstall via USB boot
  4. Download http://download.moddevices.com/releases/modduo/reset/mod-boot-fel-restore.tar.gz and extract it
Continuing:
  1. Run: ./boot-fel-restore.sh
