Audio Through USB
Using netJACK2
First, connect the MOD Duo to your PC via usb cable.
Make sure to open port 19000 on your firewall. If you use Linux with ufw, you can use:
sudo ufw allow 19000
touch /data/enable-netmanager
NOTE: You only need to run this command once.
The next the Duo boots, jack-netmanager will be loaded by default.
Delete the '/data/enable-netmanager' file inside the Duo to remove this auto-start feature.
jackd -R -P 80 -d net -a 192.168.51.1 --opus -C 2 -P 2 -i 1 -o 1 -l 4 -n mod-slave -s
Adjust the parameters as needed, but keep the client name as 'mod-slave'.
