Audio Through USB
Jump to navigation
Jump to search
Using JACK2 net
first connect the mod via usb cable to the PC. start JACK2 on your PC.
make sure to open port 19000 on your linux firewall. if you have ufw you can use:
sudo ufw allow 19000
ssh into the mod, and run:
touch /data/enable-netmanager
NOTE: You only need to run this command once. The next the Duo boots, netmanager will be loaded by default. Delete the '/data/enable-netmanager' file inside the Duo to remove this auto-start feature.
open another ssh window, and run:
jack_load mod-host
jack_load mod-peakmeter
jack_load ttymidi -i "/dev/ttyS2"
mod-ui.run
