Revision as of 09:02, 28 March 2017 by FalkTX (talk | contribs)
Stable Releases
1.3 2017/02/27 Pedalboard presets; Click-less bypass; 'MIDI Utility' category modduo-v1.3.2.357.tar
  1. Turn on your MOD
  • tuner added to 2nd display
  • several optimizations
  • Sort plugins ignoring case
  • Fix missing favicon images
  • add auto-upgrade system
  • Fix save dialog auto-focus
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
