Control Chain
About
The external controllers are connected to the MOD using a regular Ethernet patch cable and they have two connectors, what allows a next external controller to be connected, creating then a chain. The MOD will provide power supply to the controller via the patch cable.
How to use Control Chain devices
[image here]
Once a new firmware of a Control Chain device be available, the Web Graphical interface will warn you. To proceed with the upgrading click on Download button to download the latest firmware and then follow the instructions on the screen that is also replicated here.
Upgrading the Footswitch Extension device (FootEx)
- Disconnect the FootEx device from the Control Chain port
- Hold down the footswitch #1 on the FootEx device
- While the footswitch is depressed, connect the FootEx to the MOD via USB cable
- Disconnect the FootEx from the USB port
