Control Chain
Revision as of 12:33, 27 March 2017 by Crudo (talk | contribs)
About
The external controllers are connected to the MOD using a regular Ethernet patch cable and they have two connectors what allows a next external controller to be connected to the chain. The MOD will provide power supply to the controller via the patch cable.
How to use Control Chain devices
Control Chain devices list
