Troubleshooting Reinstall
If the main MOD OS becomes unbootable for some reason, the MOD will automatically boot into restore mode (used for performing OS updates).
- Turn off your MOD
- Disconnect the USB cable
Factory Reset
- Download this file: http://download.moddevices.com/releases/modduo/reset/modduo-v1.3.1.351-reset-image.raw
If you're running macOS, run:
./bootfix.osx -w ~/Downloads/modduo-v1.3.1.351-reset-image.raw
./bootfix -w ~/Downloads/modduo-v1.3.1.351-reset-image.raw
Continuing:
Reinstall via USB boot
- Download http://download.moddevices.com/releases/modduo/reset/mod-boot-fel-restore.tar.gz and extract it
Continuing:
- Run:
./boot-fel-restore.sh
- Wait for around 2 minutes, and the MOD Duo will boot into recovery mode.
