Troubleshooting
If the main Duo becomes unbootable for some reason, we need to reinstall the OS inside.
We can boot the Duo in recovery mode for safe reinstall, boot over USB if recovery partition is broken, or perform a full factory reset (which will erase all your data).
Site LOCAL
Accept from LOCAL
Deny
