Troubleshooting Reinstall
- Turn off your MOD
- Disconnect the USB cable
Factory Reset
- Click and hold down the (tiny hole) button on the back of the MOD Duo, while you power it on.
- Download this file: http://download.moddevices.com/releases/modduo/reset/modduo-v1.3.1.351-reset-image.raw
If you're running macOS, run:
./bootfix.osx -w ~/Downloads/modduo-v1.3.1.351-reset-image.raw
./bootfix -w ~/Downloads/modduo-v1.3.1.351-reset-image.raw
Continuing:
Reinstall via USB
- Download http://download.moddevices.com/releases/modduo/reset/mod-boot-fel-restore.tar.gz and extract it
Continuing:
- Run:
