Troubleshooting Reinstall
  1. Turn off your MOD
  2. Hold the left knob and footswitch down
  4. Wait 5 seconds and let go of the knob and footswitch
  7. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive
  8. Disconnect the USB cable
Factory Reset
  1. Click and hold down the (tiny hole) button on the back of the MOD Duo, while you power it on.
  3. Download this file: http://download.moddevices.com/releases/modduo/reset/modduo-v1.3.1.351-reset-image.raw
If you're running macOS, run:
./bootfix.osx -w ~/Downloads/modduo-v1.3.1.351-reset-image.raw
./bootfix -w ~/Downloads/modduo-v1.3.1.351-reset-image.raw
Continuing:
Reinstall via USB
  3. Download http://download.moddevices.com/releases/modduo/reset/mod-boot-fel-restore.tar.gz and extract it
  4. Open a terminal and 'cd' to the directory where mod-boot-fel-restore.zip was extracted, ie:
Continuing:
  1. Run:
./boot-fel-restore.sh
  1. Wait for around 2 minutes, and the MOD Duo will boot into recovery mode.
  2. Install a MOD OS release as usual.
