Troubleshooting Reinstall
  1. Turn off your MOD
  2. Hold the left knob and footswitch down
  4. Wait 5 seconds and let go of the knob and footswitch
  7. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive
  8. Disconnect the USB cable
Factory Reset
  1. Click and hold down the (tiny hole) button on the back of the MOD, while you power it on.
  3. Download this file: http://download.moddevices.com/releases/modduo/reset/modduo-v1.3.1.351-reset-image.raw
If you're running macOS, run:
./bootfix.osx -w ~/Downloads/modduo-v1.3.1.351-reset-image.raw
If you're running Linux 64bit, run: ./bootfix -w ~/Downloads/modduo-v1.3.1.351-reset-image.raw
Continuing:
  2. Power on and off the MOD (by replugging the power cable)
  3. Wait until its LEDs should turn blue, after around 30 seconds. If the LEDs don't light up after one minute, replug the power cable once again
  4. Wait until the LEDs turn red, then green
Once the LEDs are green, the MOD has finished its factory reset. It will be good as new :)
Reinstall via USB
Requirements: Linux
(work in progress, custom image needed)
