Developers
The MOD Duo as of today (release 1.1) runs Linux, version 3.4, with real time patch.
ALSA is used for the audio driver. JACK runs inside as audio server backend, with mod-host loading each LV2 plugin as a new JACK client as mod-ui as the web server.
For more information see:
Toolchain
- GCC 4.9
- glibc 2.21
- binutils 2.25
JACK
LV2
Developer mode
This includes:
- Network statistics
- Xrun counter
enable_dev_mode()
Unstable plugins
Use with caution.
Libraries
- acl
- alsa
- armadillo
- audiofile
- boost
- cairo
- dbus
- expat
- fftw/fftwf
- ffmpeg
- flac
- fluidsynth
- fontconfig
- freetype
- gio/giomm
- glib/glibmm
- glibc (v2.21)
- icu
- jack
- libffi
- libgig
- libjpeg/libturbojpeg
- liblo
- libogg
- libpng
- libsamplerate
- libsigc
- libsndfile
- libvorbis
- libxml2
- lilv
- lvtk
- mxml
- ncurses
- ne10
- pcre
- pixman
- python (v3.4)
- readline
- serd
- sord
- sratom
- systemd (v219)
- zita-convolver
- zita-resampler
USB Device Support
- Several USB-MIDI devices
Hardware Specification
CPU:
- Dual Core ARM A7 1.0GHz
- 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
- 2 knobs with LCD screen
I/O CONNECTIONS:
