| 1.2 | 2016/12/01 | Favorites; Tap-Tempo; Zeroconf; DNS fix; Minor interface changes | modduo-v1.2.0.tar |
Released on 2016/12/01
- Stable release
- limit pedalboards per bank in controller to 50
Changelog (mod-host/ui)
- add support for LV2 control outputs in modguis (see
Changelog (fixes)
Changelog (new)
Changelog (mod-host)
Changelog (mod-ui)
Changelog (mod-os)
Changelog (controller)
- initial support for some joysticks as MIDI devices (via
<a href="https://github.com/falkTX/nooice" target="_blank"> nooice</a> project, work in progress)
Changelog (mod-ui)
Changelog (mod-os)
