| 1.2 | 2016/12/01 | Favorites; Tap-Tempo; Zeroconf; DNS fix; Minor interface changes | modduo-v1.2.0.tar |
Released on 2016/12/01
- Stable release
Changelog (controller)
Changelog (mod-host/ui)
Changelog (mod-os)
Changelog (fixes)
Changelog (new)
Changelog (mod-host)
Changelog (mod-ui)
Changelog (mod-os)
Changelog (mod-ui)
Changelog (mod-os)
