| 1.2 | 2016/08/24 | Favorites; Tap-Tempo; Zeroconf; DNS fix; Minor interface changes | modduo-v1.2.0.tar |
| 1.1 | 2016/08/24 | Bluetooth Network; Control Outputs; Remember MIDI devices and connections; Tuner | modduo-v1.1.3.tar |
| 1.0 | 2016/08/24 | Fix lockups with many pedalboards; Fix single&double quotes in pedalboard names | modduo-v1.0.6.tar |
Released on 2016/12/01
- Stable release
Changelog (controller)
Changelog (mod-host/ui)
Changelog (mod-os)
Changelog (fixes)
Changelog (new)
Changelog (mod-host)
Changelog (mod-ui)
Changelog (mod-os)
Changelog (mod-ui)
Changelog (mod-os)
