| 1.2 | 2016/08/24 | Favorites; Tap-Tempo; Zeroconf; DNS fix; Minor interface changes | modduo-v1.2.0.tar |
| 1.1 | 2016/08/24 | Bluetooth Network; Control Outputs; Remember MIDI devices and connections; Tuner | modduo-v1.1.3.tar |
| 1.0.6 | 2016/08/24 | Fix lockups with many pedalboards; Fix single&double quotes in pedalboard names | modduo-v1.0.6.tar |
Release 1.2.0
Released on 2016/12/01
- Stable release
Release 1.2.0-RC3
Release 1.2.0-RC2
Release 1.2.0-RC1
Release 1.1.3
Release 1.1.2
Release 1.1.1
Release 1.1.0
Release 1.1.0-RC3
Release 1.1.0-RC2
Release 1.1.0-RC1
Changelog (controller)
Changelog (mod-host/ui)
Changelog (mod-os)
Release 1.0.6
Release 1.0.5
Release 1.0.4
Release 1.0.3
Release 1.0.2
Release 1.0.1
Changelog (fixes)
Changelog (new)
Release 1.0.0
Changelog (mod-host)
Changelog (mod-ui)
Changelog (mod-os)
Changelog (mod-ui)
Changelog (mod-os)
