Revision as of 15:56, 1 December 2016 by FalkTX (talk | contribs)
Stable Releases
1.2 2016/08/24 Favorites; Tap-Tempo; Zeroconf; DNS fix; Minor interface changes modduo-v1.2.0.tar
1.1 2016/08/24 Bluetooth Network; Control Outputs; Remember MIDI devices and connections; Tuner modduo-v1.1.3.tar
1.0.6 2016/08/24 Fix lockups with many pedalboards; Fix single&double quotes in pedalboard names modduo-v1.0.6.tar
1.0.5 2016/08/17 Fix browsing pedalboards using midi programs modduo-v1.0.5.tar
1.0.4 2016/08/08 Minor bug fix; Released as stable 1.0 modduo-v1.0.4.tar
1.0.3 2016/08/04 Add unstable flag in plugin store; Faster screenshots modduo-v1.0.3.tar
1.0.2 2016/07/28 Overall bugfix; Add 'Dev mode' modduo-v1.0.2.tar
1.0.1 2016/07/22 Load remote pedalboards fix; Always generate screenshots modduo-v1.0.1.tar
1.0.0 2016/07/15 Share pedalboards; Auto-upgrade; Overall bugfix modduo-v1.0.0.tar
0.15.0 2016/06/21 Preset support; Fixed xruns modduo-v0.15.0e.tar
0.14.0 2016/05/23 Bugfixes only modduo-v0.14.0.tar
0.13.0 2016/05/09 Allow javascript in modguis; Optimizations to plugin store modduo-v0.13.0.tar
0.12.2 2016/04/19 Add "default" pedalboard modduo-v0.12.2.tar
0.11.3 2016/03/22 Implemented leds peak-meter modduo-v0.11.3.tar
0.10.4 2016/03/08 Volume/gain via controller; Access banks after disconnecting USB cable; Firefox compatible modduo.tar
0.9.0 2016/02/18 Initial version modduo.tar
  1. Turn on your MOD
At this point the MOD will start auto-updating. DO NOT TURN IT OFF! Please wait until the update finishes.
The MOD will auto-reboot when the process is complete. User data will remain untouched.
<a href="http://download.moddevices.com/releases/modduo/modduo-v1.2.0.255.tar" class="button">Download</a> <a href="#howto" class="instructions">How to upgrade?</a>
Release 1.2.0
Released on 2016/12/01
  • Stable release
Release 1.2.0-RC3
Release 1.2.0-RC2
Release 1.2.0-RC1
  • add tap tempo as controller actuator   (by addressing a time-based linear parameter to a footswitch)
  • add zeroconf support, using <a href="http://modduo.local/" target="_blank">http://modduo.local/</a>
<a href="http://download.moddevices.com/releases/modduo/modduo-v1.1.3.tar" class="button">Download</a> <a href="#howto" class="instructions">How to upgrade?</a>
Release 1.1.3
Release 1.1.2
Release 1.1.1
Release 1.1.0
Release 1.1.0-RC3
Release 1.1.0-RC2
Release 1.1.0-RC1
Changelog (controller)
  • tuner added to 2nd display
Changelog (mod-host/ui)
  • add support for LV2 control outputs in modguis (see <a href="http://moddevices.com/ns/modgui/#MonitoredOutput" target="_blank"> modgui:MonitoredOutput</a>)
  • several optimizations
Changelog (mod-os)
<a href="http://download.moddevices.com/releases/modduo/modduo-v1.0.6.tar" class="button">Download</a> <a href="#howto" class="instructions">How to upgrade?</a>
Release 1.0.6
Release 1.0.5
Release 1.0.4
Release 1.0.3
Release 1.0.2
  • Sort plugins ignoring case
Release 1.0.1
Changelog (fixes)
  • Fix missing favicon images
Changelog (new)
Release 1.0.0
Changelog (mod-host)
Changelog (mod-ui)
  • add auto-upgrade system
Changelog (mod-os)
  • initial support for some joysticks as MIDI devices (via <a href="https://github.com/falkTX/nooice" target="_blank"> nooice</a> project, work in progress)
Changelog (mod-ui)
  • Fix save dialog auto-focus
Changelog (mod-os)
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
