| 1.0.6 | 2016/08/24 | Fix lockups with many pedalboards; Fix single&double quotes in pedalboard names | modduo-v1.0.6.tar |
| 1.0.5 | 2016/08/17 | Fix browsing pedalboards using midi programs | modduo-v1.0.5.tar |
| 1.0.4 | 2016/08/08 | Minor bug fix; Released as stable 1.0 | modduo-v1.0.4.tar |
| 1.0.3 | 2016/08/04 | Add unstable flag in plugin store; Faster screenshots | modduo-v1.0.3.tar |
| 1.0.2 | 2016/07/28 | Overall bugfix; Add 'Dev mode' | modduo-v1.0.2.tar |
| 1.0.1 | 2016/07/22 | Load remote pedalboards fix; Always generate screenshots | modduo-v1.0.1.tar |
| 1.0.0 | 2016/07/15 | Share pedalboards; Auto-upgrade; Overall bugfix | modduo-v1.0.0.tar |
| 0.15.0 | 2016/06/21 | Preset support; Fixed xruns | modduo-v0.15.0e.tar |
| 0.14.0 | 2016/05/23 | Bugfixes only | modduo-v0.14.0.tar |
| 0.13.0 | 2016/05/09 | Allow javascript in modguis; Optimizations to plugin store | modduo-v0.13.0.tar |
| 0.12.2 | 2016/04/19 | Add "default" pedalboard | modduo-v0.12.2.tar |
| 0.11.3 | 2016/03/22 | Implemented leds peak-meter | modduo-v0.11.3.tar |
| 0.10.4 | 2016/03/08 | Volume/gain via controller; Access banks after disconnecting USB cable; Firefox compatible | modduo.tar |
| 0.9.0 | 2016/02/18 | Initial version | modduo.tar |
Downloads
Release 1.2.0
Released on 2016/12/01
- Stable release
Release 1.2.0-RC3
Release 1.2.0-RC2
Release 1.2.0-RC1
Release 1.1.3
Release 1.1.2
Release 1.1.1
Release 1.1.0
Release 1.1.0-RC3
Release 1.1.0-RC2
Release 1.1.0-RC1
Changelog (controller)
Changelog (mod-host/ui)
Changelog (mod-os)
Release 1.0.6
Release 1.0.5
Release 1.0.4
Release 1.0.3
Release 1.0.2
Release 1.0.1
Changelog (fixes)
Changelog (new)
Release 1.0.0
Changelog (mod-host)
Changelog (mod-ui)
Changelog (mod-os)
Changelog (mod-ui)
Changelog (mod-os)
