How to upgrade
- 1.1 Release 1.2
- 1.2 Release 1.1
- 1.3 Release 1.0
- 1.4 Release 0.15.0
- 1.5 Release 0.14.0
- 1.6 Release 0.13.0
- 1.7 Release 0.12.2
- 1.8 Release 0.11.3
- 1.9 Release 0.10.4
- 1.10 Release 0.9.0
Release 1.2.0
Released on 2016/12/01
- Stable release
Release 1.2.0-RC3
Release 1.2.0-RC2
Release 1.2.0-RC1
Release 1.1.3
Release 1.1.2
Release 1.1.1
Release 1.1.0
Release 1.1.0-RC3
Release 1.1.0-RC2
Release 1.1.0-RC1
Changelog (controller)
Changelog (mod-host/ui)
Changelog (mod-os)
Release 1.0.6
Release 1.0.5
Release 1.0.4
Release 1.0.3
Release 1.0.2
Release 1.0.1
Changelog (fixes)
Changelog (new)
Release 1.0.0
Changelog (mod-host)
Changelog (mod-ui)
Changelog (mod-os)
Changelog (mod-ui)
Changelog (mod-os)
