Revision as of 15:35, 1 December 2016 by FalkTX (talk | contribs)
WIP page
<a href="http://download.moddevices.com/releases/modduo/modduo-v1.2.0.255.tar" class="button">Download</a> <a href="#howto" class="instructions">How to upgrade?</a>
Release 1.2.0
Released on 2016/12/01
  • Stable release
Release 1.2.0-RC3
Release 1.2.0-RC2
Release 1.2.0-RC1
  • add tap tempo as controller actuator   (by addressing a time-based linear parameter to a footswitch)
  • add zeroconf support, using <a href="http://modduo.local/" target="_blank">http://modduo.local/</a>
<a href="http://download.moddevices.com/releases/modduo/modduo-v1.1.3.tar" class="button">Download</a> <a href="#howto" class="instructions">How to upgrade?</a>
Release 1.1.3
Release 1.1.2
Release 1.1.1
Release 1.1.0
Release 1.1.0-RC3
Release 1.1.0-RC2
Release 1.1.0-RC1
Changelog (controller)
  • tuner added to 2nd display
Changelog (mod-host/ui)
  • add support for LV2 control outputs in modguis (see <a href="http://moddevices.com/ns/modgui/#MonitoredOutput" target="_blank"> modgui:MonitoredOutput</a>)
  • several optimizations
Changelog (mod-os)
<a href="http://download.moddevices.com/releases/modduo/modduo-v1.0.6.tar" class="button">Download</a> <a href="#howto" class="instructions">How to upgrade?</a>
Release 1.0.6
Release 1.0.5
Release 1.0.4
Release 1.0.3
Release 1.0.2
  • Sort plugins ignoring case
Release 1.0.1
Changelog (fixes)
  • Fix missing favicon images
Changelog (new)
Release 1.0.0
Changelog (mod-host)
Changelog (mod-ui)
  • add auto-upgrade system
Changelog (mod-os)
  • initial support for some joysticks as MIDI devices (via <a href="https://github.com/falkTX/nooice" target="_blank"> nooice</a> project, work in progress)
Changelog (mod-ui)
  • Fix save dialog auto-focus
Changelog (mod-os)
  • fix inverted DAC controls
  • implemented leds peak-meter
  • removed disconnect button
  • fix boot issues
  • Initial Version
