Revision as of 15:26, 1 December 2016 by FalkTX (talk | contribs) (Created page with "WIP page <h1 id="release_1_2">Release 1.2</h1> <div class="buttons"> <a href="http://download.moddevices.com/releases/moddu...")
(diff) ← Older revision | Latest revision (diff) | Newer revision → (diff)
WIP page
                   <a href="http://download.moddevices.com/releases/modduo/modduo-v1.2.0.255.tar" class="button">Download</a>
                   <a href="#howto" class="instructions">How to upgrade?</a>
  • Release 1.2.0
                               Released on 2016/12/01
    • Stable release
  • Release 1.2.0-RC3
  • Release 1.2.0-RC2
  • Release 1.2.0-RC1
    • add tap tempo as controller actuator   (by addressing a time-based linear parameter to a footswitch)
    • add zeroconf support, using <a href="http://modduo.local/" target="_blank">http://modduo.local/</a>
                   <a href="http://download.moddevices.com/releases/modduo/modduo-v1.1.3.tar" class="button">Download</a>
  • Release 1.1.3
  • Release 1.1.2
  • Release 1.1.1
  • Release 1.1.0
  • Release 1.1.0-RC3
  • Release 1.1.0-RC2
  • Release 1.1.0-RC1
    Changelog (controller)
    • tuner added to 2nd display
    Changelog (mod-host/ui)
    • add support for LV2 control outputs in modguis (see <a href="http://moddevices.com/ns/modgui/#MonitoredOutput" target="_blank"> modgui:MonitoredOutput</a>)
    • several optimizations
    Changelog (mod-os)
                   <a href="http://download.moddevices.com/releases/modduo/modduo-v1.0.6.tar" class="button">Download</a>
  • Release 1.0.6
  • Release 1.0.5
  • Release 1.0.4
  • Release 1.0.3
  • Release 1.0.2
    • Sort plugins ignoring case
  • Release 1.0.1
    Changelog (fixes)
    • Fix missing favicon images
    Changelog (new)
  • Release 1.0.0
    Changelog (mod-host)
    Changelog (mod-ui)
    • add auto-upgrade system
    Changelog (mod-os)
  • Release 0.15.0
    • initial support for some joysticks as MIDI devices (via <a href="https://github.com/falkTX/nooice" target="_blank"> nooice</a> project, work in progress)
  • Release 0.14.0
  • Release 0.13.0
  • Release 0.12.2
    Changelog (mod-ui)
    • Fix save dialog auto-focus
    Changelog (mod-os)
    • fix inverted DAC controls
  • Release 0.11.3
    • implemented leds peak-meter
  • Release 0.10.4
    • removed disconnect button
    • fix boot issues
  • Release 0.9.0
    • Initial Version
