MOD Duo User Guide
Audio inputs
Audio outputs
Headphone output
Power input
Control chain
USB-A host
USB-B slave
DIN-MIDI
General knob actions
Left knob actions
Right knob actions
General footswitch actions
- width: 180 mm
- length: 160 mm
- height: 74.7 mm
Audio flow
The graphic below represents the signal-flow of the audio inside the MOD Duo.
Current pedalboard
Volume and gains
- Low: -22.0 dBu
- Medium: -9.5 dBu
- High: +3.0 dBu
- jack
- mod-host
- mod-ui
- ttymidi
- release
- restore (hexadecimal)
- system (hexadecimal)
- controller (hexadecimal)
Hooking up the MOD Duo
Wiring examples
Guitar
- semi-accoustic setup
Vocals
- MIC -> MOD -> DI -> PA
Keys
- HW Synth -> MOD
- ePiano -> MOD
- keyboard -> MOD
Exotic
TODO: Add exotic use cases
- Chapman stick
- Wind instruments
- Accoustic instruments
