Audio Through USB
Jump to navigation
Jump to search
Using JACK2 net
first connect the mod via usb cable to the PC. start JACK2 on your PC.
note down the IP assigned to your PC by the MOD. on linux this can be done by using:
ifconfig usb0 | awk 'sub("addr:","")' | awk '{print $2}'
note this value, we'll be referencing it as 'XYZ'.
make sure to open port 19000 on your linux firewall. if you have ufw you can use:
sudo ufw allow 19000
With that setup, load jack2 netmanager client, by running on your PC:
jack_load netmanager -i "-a 192.168.51.XYZ"
then ssh into the mod, and run:
systemctl stop jack2 mod-host mod-peakmeter ttymidi mod-ui
jackd -R -P 80 -d net -a 192.168.51.XYZ -C 2 -P 2 -i 0 -o 0 -l 9 -n mod-duo
open another ssh window, and run:
jack_load mod-host
jack_load mod-peakmeter
jack_load ttymidi -i "/dev/ttyS2"
mod-ui.run
