MOD Duo User Guide
The MOD Duo when powered up
Side-shot of the MOD Duo
Wireframe of the top-view, exposing the two footswitch-LED-pairs, the two knobs, the two displays, the two inputs with peak-LEDs, two outputs with peak-LEDs and the headphone output
Wireframe of the back-view, exposing the power supply input, control-chain port, USB-A host port, USB-B slave port and a DIN-MIDI input/output pair
The following sub-sections give information about the different physical device features: the inputs, outputs, actuators, display and finally the dimensions of the device.
The MOD Duo has two independant audio inputs
Left knob actions
  • Hold the left knob to access and exit the device menu
  • Press the left knob to enter the selected sub-menu or toggle the selected option
Right knob actions
  • Hold the right knob to access and exit the tuner
  • width: 180 mm
  • length: 160 mm
  • height: 74.7 mm
Device menu (HMI)
  1. Repeat the procedure to navigate to and select a different pedalboard
  2. Use the footswitches on the MOD Duo to cycle through the pedalboards inside the currently active bank (only if set up through the web interface)
  3. Use MIDI program changes to select the currently active bank (only if set up through the web interface)
Current pedalboard
Volume and gains
  • Low: -22.0 dBu
  • Medium: -9.5 dBu
  • High: +3.0 dBu
  • jack
  • mod-host
  • mod-ui
  • ttymidi
  • release
  • restore (hexadecimal)
  • system (hexadecimal)
  • controller (hexadecimal)
Hooking up the MOD Duo
Wiring examples
Guitar
  4. semi-accoustic setup
Vocals
  1. MIC -> MOD -> DI -> PA
  2.  ?
Keys
  1. HW Synth -> MOD
  2. ePiano -> MOD
  3. keyboard -> MOD
Exotic
TODO: Add exotic use cases
  1. Chapman stick
  2. Wind instruments
  3. Accoustic instruments
