MOD Duo User Guide
Revision as of 17:07, 2 November 2016 by Jesseverhage (talk | contribs)
Device menu (HMI)
  1. Repeat the procedure to navigate to and select a different pedalboard
  2. Use the footswitches on the MOD Duo to cycle through the pedalboards inside the currently active bank (only if set up through the web interface)
  3. Use MIDI program changes to select the currently active bank (only if set up through the web interface)
Current pedalboard
Volume and gains
  • Low: -22.0 dBu
  • Medium: -9.5 dBu
  • High: +3.0 dBu
  • jack
  • mod-host
  • mod-ui
  • ttymidi
  • release
  • restore (hexadecimal)
  • system (hexadecimal)
  • controller (hexadecimal)
Hooking up the MOD Duo
Wiring examples
Guitar
  4. semi-accoustic setup
Vocals
  1. MIC -> MOD -> DI -> PA
  2.  ?
Keys
  1. HW Synth -> MOD
  2. ePiano -> MOD
  3. keyboard -> MOD
Exotic
TODO: Add exotic use cases
  1. Chapman stick
  2. Wind instruments
  3. Accoustic instruments
