MOD Duo User Guide
Device menu (HMI)
  1. Repeat the procedure to navigate to and select a different pedalboard
  2. Use the footswitches on the MOD Duo to cycle through the pedalboards inside the currently active bank (only if set up through the web interface)
  3. Use MIDI program changes to select the currently active bank (only if set up through the web interface)
Current pedalboard
Volume and gains
  • Low: -22.0 dBu
  • Medium: -9.5 dBu
  • High: +3.0 dBu
  • jack
  • mod-host
  • mod-ui
  • ttymidi
  • release
  • restore (hexadecimal)
  • system (hexadecimal)
  • controller (hexadecimal)
Hooking up the MOD Duo
For the first scenario, the only connection that you need to make is from the USB B port on the MOD Duo to your computer. (Bluetooth is possible in case that is preferred) For the second scenario, it is possible to remove the connection to the computer completely, the MOD Duo works perfectly fine as a standalone device!
In the section below you can find examples of setups that use the MOD Duo, split up into different categories.
Wiring examples
Guitar
Vocals
Keys
Exotic
