MOD Duo User Guide
Current pedalboard
Volume and gains
- Low: -22.0 dBu
- Medium: -9.5 dBu
- High: +3.0 dBu
- jack
- mod-host
- mod-ui
- ttymidi
- release
- restore (hexadecimal)
- system (hexadecimal)
- controller (hexadecimal)
