MOD Duo User Guide
Device menu (HMI)
From this point onwards, you can use multiple ways of navigating through the pedalboards in the active bank: 1. Repeat the procedure to navigate to and select a different pedalboard 2. Use the footswitches on the MOD Duo to cycle through the pedalboards inside the currently active bank (only if set up through the web interface) 3. Use MIDI program changes to select the currently active bank (only if set up through the web interface)
Current pedalboard
Volume and gains
Hooking up the MOD Duo
Wiring examples
Guitar
Vocals
Keys
Exotic
