Troubleshooting
We do this by starting the restore mode with a "force install" flag.
The method for this special mode is:
- Turn off your MOD
- Download the latest release from http://download.moddevices.com/releases/
- Disconnect the USB cable
Site LOCAL
Accept from LOCAL
