Troubleshooting
We do this by starting the restore mode with a "force install" flag.
The method for this special mode is:
- Turn off your MOD
The MOD is now booting into restore mode, but will allow the installation of any valid MOD release (including the same as already installed or downgrades). Continuing...
- Download the latest release from http://download.moddevices.com/releases/
- Disconnect the USB cable
Site LOCAL
Accept from LOCAL
