Troubleshooting
Revision as of 15:00, 29 September 2016 by FalkTX (talk | contribs)
We do this by starting the restore mode with a "force install" flag.
The method for this special mode is:
  1. Turn off your MOD
  2. Hold the left knob and footswitch down
  4. Wait 5 seconds and let go of the knob and footswitch
To continue:
  2. Download the latest release from http://download.moddevices.com/releases/
  3. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive
  4. Disconnect the USB cable
Site LOCAL
Accept from LOCAL
Deny
