Troubleshooting
We do this by starting the restore mode with a "force install" flag.
The method for this special mode is:
- Turn off your MOD
To continue: 5. Connect the MOD to your PC (if not done yet) and wait for a new mass storage drive to appear 6. Download the latest release from http://download.moddevices.com/releases/ 7. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive 8. Disconnect the USB cable
Site LOCAL
Accept from LOCAL
