Troubleshooting
We do this by starting the restore mode with a "force install" flag.
The method for this special mode is:
1. Turn off your MOD 2. Hold the left knob and footswitch down 3. Turn on the MOD (while still holding the knob and footswitch down) 4. Wait 5 seconds and let go of the knob and footswitch
To continue: 5. Connect the MOD to your PC (if not done yet) and wait for a new mass storage drive to appear 6. Download the latest release from http://download.moddevices.com/releases/ 7. Copy the modduo*.tar file onto the new drive and use your OS option to safely remove the drive 8. Disconnect the USB cable
Site LOCAL
Accept from LOCAL
