Troubleshooting Windows Connection
Revision as of 10:32, 29 September 2016 by FalkTX (talk | contribs)
Below follows a tutorial on how to install it.
If your system reports the driver as missing, make windows look for drivers and skip to step 5.
2. Find the MOD Duo device. It either appears as 'Duo Ethernet' under 'Unknown devices' or as a USB Serial device.
If you have 'Duo Ethernet' as unknown device, select it.
5. Click the 'Browse' button and select the folder where you extracted the contents of the mod-duo-rndis.zip file, then click 'Next'.
8. If everything is working correctly, the Duo will appear as 'USB Ethernet/RNDIS Gadget' under 'Network adapters'
