Troubleshooting Windows Connection
Below follows a tutorial on how to install it.
If your system reports the driver as missing, make windows look for drivers and skip to step 5.
1. Press the windows key and 'R' at the same time to get the 'Run' dialog. Type "devmgmt.msc" and press enter.
This will open the Device Manager.
2. Find the MOD Duo device. It either appears as 'Duo Ethernet' under 'Unknown devices' or as a USB Serial device.
If you have 'Duo Ethernet' as unknown device, skip to step 4.
3. Double click the 'USB Serial Device', and navigate to the 'Details' tab on the new window that appears.
Change the 'Property' combo-box
