Developers
The MOD Duo as of today (release 1.1) runs Linux, version 3.4, with realtime patch.
ALSA is used for the audio driver. JACK runs inside as audio server backend, with mod-host loading each LV2 plugin as a new JACK client.
The CPU is cortex A7, running at constant 912MHz.
The default compile flags are:
-mcpu=cortex-a7 -mtune=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard -mvectorize-with-neon-quad
For more information see:
Toolchain
- GCC 4.9
- glibc 2.21
- binutils 2.25
Libraries
- acl
- alsa
- armadillo
- audiofile
- boost
- cairo
- dbus
- expat
- fftw/fftwf
- ffmpeg
- flac
- fluidsynth
- fontconfig
- freetype
- gio/giomm
- glib/glibmm
- icu
- jack
- libffi
- libgig
- libjpeg/libturbojpeg
- liblo
- libogg
- libpng
- libsamplerate
- libsigc
- libsndfile
- libvorbis
- libxml2
- lilv
- mxml
- ncurses
- ne10
- pcre
- pixman
- python (3.4)
- readline
- serd
- sord
- sratom
- systemd (219)
- zita-convolver
- zita-resampler
JACK
Developers can create JACK clients to interact with the audio data directly (without being managed by the plugin host).
LV2
USB Device Support
- Several USB-MIDI devices
Hardware Specification
CPU:
- Dual Core ARM A7 1.0GHz
- 4GB Flash Storage, 1GB RAM
AUDIO CODEC:
CONTROLLER:
- 2 knobs with LCD screen
I/O CONNECTIONS:
