In this page you find instructions to connect your computer to the MOD Duo using Bluetooth.
Please note that the MOD Duo unit does not include a Bluetooth chip inside, you have to plug a Bluetooth USB dongle on MOD Duo for this to work.
Display options
The controller has a menu option dedicated to Bluetooth. To access this menu please click and hold the left knob and find the "Bluetooth" item, click the left knob to access it.
Status:... shows the current Bluetooth status.
- Unavailable - no Bluetooth stick is plugged in the MOD Duo
- Unsupported - the Bluetooth version of the stick in use is too old (needs >= Bluetooth 3)
Name:... shows the Bluetooth device name for your specific MOD Duo.
Usually includes batch and serial number as suffix for uniqueness.
You can customize this name by creating a file named '/data/bluetooth/name' inside the MOD Duo. Its contents define the name.
Address:... shows the MAC address of the current Bluetooth stick in the MOD Duo.
Connecting using Bluetooth
The process to connect to MOD Duo via Bluetooth is pretty simple.
Windows
1. Turn on the MOD Duo and plug a Bluetooth USB stick into it
3. Open the MOD Duo controller menu (by holding the left knob down), go to the Bluetooth menu and enable discovery.
Mac OS
3. Select the MOD Duo and click 'Continue'
5. After the setup finishes, connect to the MOD DUO Bluetooth network
2. Wait for it to boot
4. Use your Bluetooth manager application to look for Bluetooth devices
5. Select the MOD Duo and connect to it
6. Join the Bluetooth network created by the MOD Duo
