Revision as of 15:40, 20 September 2016 by FalkTX (talk | contribs)
Display options
Status:... shows the current bluetooth status.
- Unavailable - no bluetooth stick is plugged in the MOD
- Unsupported - the bluetooth version of the stick in use is too old (needs >= bluetooth 3)
- Starting... - bluetooth service is starting
- Disconnected - bluetooth active, no devices connected and not discoverable
- Discoverable - bluetooth active, discoverable (and perhaps with devices connected)
- Connected - bluetooth active, at least 1 device connected but not discoverable
Name:... shows the bluetooth device name for your specific MOD.
Usually includes batch and serial number as suffix for uniqueness.
Address:... shows the MAC address of the current bluetooth stick in the MOD.
Connecting using bluetooth
The process to connect to MOD Duo via bluetooth is pretty simple.
Windows
1. Turn on the MOD Duo and plug a Bluetooth USB stick into it
2. Right-click the Windows bluetooth icon and click on "Join a Personal Area Network"
3. Open the MOD controller menu (by holding the left knob down), go to the bluetooth menu and enable discovery.
Mac OS
3. Select the MOD Duo and click 'Continue'
5. After the setup finishes, connect to the MOD DUO bluetooth network
There are quite a few different bluetooth manager applications under Linux, so we won't cover them all here.
2. Wait for it to boot
4. Use your bluetooth manager application to look for bluetooth devices
5. Select the MOD Duo and connect to it
6. Join the bluetooth network created by the MOD Duo
